Topic: Moj Heli moj SETUP (samo setup) (Read 14500 times) previous topic - next topic
Odg: Moj Heli moj SETUP
Flight Style: 3d
FBL System:Bavarian Demon 3sx
Motor: Xnova 1120kv
Pinion: 22
Target Headspeed(s):2500
ESC:Hobbywing 120a v4
Governor:da
BEC:ne
RX:Taranis
Cyclic Servos:Kts 815
Tail Servo:Kst 805
Main Blades:Sab 570
Tail Blades:Sab 95
Lipos:zippy 5000 40c 6s
Weight no batt:2,6kg
Flight Style: 3d
Motor: Xnova 890kv
Pinion: 21
Target Headspeed(s):samo da se vrti sto vise to bolje
ESC:Hobbywing 60a v4
Governor:da
BEC:ne
RX:Taranis
Cyclic Servos:Kts 215
Tail Servo:Kst 565x
Main Blades:Sab 380
Tail Blades:Sab 70
Lipos:zippy 1800 40c 6s
Weight no batt:kg
Re: Moj Heli moj SETUP (samo setup)
Flight Style: 3d
FBL System:Neo
Motor: Scorpion hk-4015 1070kv
Pinion: 15 TREBA 23
Target Headspeed(s):2300
ESC:Hobbywing 80a v4
Governor:da
BEC:ne
RX:Vcontrol
Cyclic Servos:gs-303
Tail Servo:tgn 565
Main Blades:rt 477
Tail Blades:fan-key 75
Lipos:nanotec 2650
Weight no batt:1668g +batt 388g
