Topic: Turnigy Mega 400w 20A novi punjač na HC (Read 2451 times) previous topic - next topic
TURNIGY MEGA 400W Lithium Polymer Battery Charger
          Are you ready to charge your packs faster than ever before or   are you looking to take advantage of the new high C charge rate on the   new Zippy and Turnigy battery packs?
The Turnigy Mega 400W is an   Pro level balancing charger and discharger which can handle up to 6   cells/20A, LiPo/LiFe to 6S and NiMH/NiCd up to 18S. Bundled with the   Turnigy Mega is an array of charing wires and plugs, suitable for most   applications.
Features;
Microprocessor   controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell   balancing charge & discharge
Li-ion, LiPo and LiFe capable
Ni-Cd   and NiMH capable
High-power   and high-performance circuit
Store function, allows   safe storage current
Data storage (Store up to 10 packs in memory)
[/size]Cyclic   charging/discharging
Spec.
Input voltage: 11.0 – 18.0Volt
Charge   current: 0.1 – 20.0A
Discharge current: 0.1   – 5.0A
Maximum charge capacity: 400W @ input   voltage >15V
Maximum discharge capacity: 25W
Current   drain for balancing Li-po: 200mAh/cell
Lithium   (LiPo/LiIo/LiFe) battery cell count: 1 – 6 series
NiCd/NiMH   battery cell count: 1 – 18 series
Pb battery   voltage: 2 –24V
Battery setup memories: 10
Intelligent   temperature control: Yes
Weight: 820g
Dimensions   : 152X145X57mm
Including;
1 x Turnigy Mega 400W charger
1 x   JST XH Adapter
1 x Banana plug w/ Female Mini JST
1 x Banana   plug w/ Female Futaba
1 x Banana plug w/ Aligator clip
1 x   Banana plug w/ Losen wires
1 pair Aligator clip
This charger has a JST-XH charge plug, which makes it compatible with   Zippy, HXT,TURNIGY and any pack with a JST adapter.
I dobra mu je cijena 79 Usa + poštarina.
http://www.rcwings.webs.com/
Odg: Turnigy Mega 400w 20A novi punjač na HC
Trebat će ti opaki DC izvor.. 400W (20 A i  cca 11-18 V), za to moraš 'ubiti'  barem 2 PC napajanja, jer ona koja se deklarirana na 400 W teško da imaju preko 250 W.
Inaće, svidja mi se ... dolazi vrijeme elektroautomobila, zar ne ! ;)
