Topic: Flashanje raceflighta na F4 Revo board (Read 9973 times) previous topic - next topic
Odg: Flashanje raceflighta na F4 Revo board
ovo piše na http://www.readytoflyquads.com/flip32-f4
*here Boards are shipped BetaFlight with buzzer fixed, Buzzer is working out of the box from default port*
*RaceFlight please connect Buzzer to labeled "RSSI" port. These port are swapped in the firmware, but are working . Buzzer should be connected to Rssi Port, no code changed need, the printing on the board from the RF and BF are not the same.
pa kazem ti...sa banggooda f4 cc3d revo nisam uspio...sa rtfq cc3d revo jesam...323 full bin..buzzer 3pinski koji je na plocici sa tranzistorom i kondenzatorom i sve to na m6
Sent from my SM-G900F using Tapatalk
sa rtfq je kvalitetnija plocka i ne treba micanje onog kondenzatora da bi radio sbus
Aje probat ću s sklopom na M6. Hvala na info.
Moja je sa BGa, vidi ovaj link, ali izgleda potpuno isto kao ova FlipF4 sa rtfq i isto mi radi SBUS bez micanja konde.
ja imam omnibus f4 board,cc3d revo firmware ide gore,na raceflightu i beti ista stvar sa buzerom...radi mi tak da ga mogu samo ukljucit sa 3way svitchom...pa mogu imat samo jedan flight mode...bez obzira kako podesim modove...spojio sam ga na buzer pinove na fc-u...
Radi buzzer na raceflightu, board sa banggood-a sa firm REVO_BB425_STD.bin samo je izlaz + na RSSI. obični dvopinski buzzer.
