Topic: P: FPV RC Avion Durafly Turnigy EFXtra Racer V2 (Read 2696 times) previous topic - next topic
Prodajem Durafly EFXtra Racer V2 avion, letio svega nekoliko puta, precizan, zabavan i vrlo brz model aviona. Postoje 2 varijante u kojoj ga se može kupiti:
1. Model aviona (sa setupom i 2 baterije Turnigy Bolt 1800mAh 4S 65C) 1100kn
2. Komplet sa FPV-om (kamera HS1177, 5,8GHz Immersion predajnik i HK mini OSD) 1400kn
U obje varijante potrebna je vaša upravljačka stanica i prijemnik. Ide i nešto rezervnih dijelova. Može biti zapakiran za slanje poštom.
Kontakt na 0958511305 ili PM.
Features:• 100mph+ performance right out of the box (on 4S set-up).• Specially designed 3536-1780kv brushless motor with high-speed Japanese bearings.• Powerful and fast 9g digital servos.• 3S or 4S as standard • Supplied with 8x6 propeller for 3S and 7x6.5 propeller for 4S set-ups.• Super Compressed EPO foam construction.• Larger internal capacity• Glass and carbon fiber reinforcement throughout the airframe.• Full wing length spar• No glue assembly. Just clicks and screws together in minutes.• Ball link control system.• FPV Mount• Slope soaring nose cone• Full complement of spare parts available.Specs:Wingspan: 975mm (38.4”)Length: 760mm (29.9”)Flying Weight: ~ 920g (32.45oz)Wing Loading: 61g/dm.dmESC: 60A AerostarMotor: 3536-1780kv BrushlessBattery: 1800~2400mAh 4S 65C or 2200~2600mAh 3S 65C (not supplied)Prop: 7x6.5 for 4S or 8x6 for 3S (supplied)Controls: 4 Channel (Throttle, Ailerons, Elevator, Rudder)Spinner: Custom made aluminumFPV Racing Canopy: IncludedSlope nose cone: Included
Odg: P: FPV RC Avion Durafly Turnigy EFXtra Racer V2
Prodano
