Topic: P: Wemotec Evo Midi 11 blade 90 mm EDF turbinu (Read 2642 times) previous topic - next topic
 Prodajem Wemotec Evo Midi 11 blade 90 mm EDF turbinu s motorom za 6S bateriju:
Vrhunska i vrlo efikasna turbina odličnog zvuka.
Turbina:
https://shop.wemotec.com/Midi-Fan-evo-11-blades
Material: Nylon, ABS, Aluminium
 Weight: about 102 grams, incl. intake lip
 Power range: 1.000-4.000 W
 Max. rpm: 50.000 U/min
 Rotor: 11-blades (87,5 mm) glass reinforced Nylon
 Set: all parts, incl. instruction
 Ageom.: 49,4 qcm
 Aeff.: 45,6 qcm
 Thrust: 7-50 N
Motor: Turnigy SK3 Fandrive - 3659-1900kv (90mm EDF)
https://hobbyking.com/en_us/turnigy-sk3-fandrive-3659-1900kv-90mm-edf.html?___store=en_us
Specs.
 Motor Type: 4 Pole Inrunner
 Winding: 2.5D
 Voltage: 5~6S Lipoly
 RPM/V: 1900kv
 Internal resistance: 0.011 Ohm
 Max Loading: 80A
 Max Power: 1770W
 Shaft Dia: 5.0mm
 Weight: 249g
 Motor Plug: 3.5mm Bullet Connector
 For 90mm EDF Units
Bila je u Fly Fly Mirage 2000 D i ovako ga gurala:
 http://www.youtube.com/watch?v=VOe75fZEDKc
Cijena novoga bez šipinga 890 kn
Moja cijena 550 kn  plus poštarina
Info na pp ili na mob: 095 9007 654
