Topic: P: DM55 GAS engine (Read 3310 times) previous topic - next topic
P: DM55 GAS engine
Prodajem bemzinac DM55,  55ccm, ispravan
DM55 55cc 2-Stroke Gas Engine w/ CDI
Specification:
Bore x stroke: 45 x 35mm
Piston displacement: 55.665cc
Max. power: 5.5HP/7,500rpm 6800RPM-22x10 2 blade wood prop
Min. idle rotating speed: 1400rpm
Rotate Speed: 1,400rpm-9,000rpm
Compression ratio: 7.5:1
Electronic ignition-CDI
Spark plug: NGK CM-6 style
Carburetor: Walbro choke type/diaphragm
Start mode: Anticlockwise Push Prop Start
Dimensions: 195 x 140 x 210mm
Weight: 1.490kg
