Topic: Novi Spektrum parkflyer prijemnici - 6110 serija (Read 3318 times) previous topic - next topic
Evo ih jos manjih, 3.5 grama, pa nek onda netko kaze Futaba :)
Evo sa sajta:
Spektrum’s 2.4GHz DSM2 technology gets even smaller with the AR6110 6-channel DSM2 Microlite Park Flyer Receiver. The AR6110 weighs less than 3.5 grams making it the lightest 6-channel conventional plug aircraft receiver on the market. Antenna locations give the AR6110 improved signal path diversity. The receiver also features a red LED (labeled with H) that indicates the number of holds that have occurred since the receiver was last powered on. The AR6110 is compatible with all aircraft DSM2 radios and module systems. It is designed for park flyer use only.
Key Features:
    * 6-channel park flyer receiver
    * QuickConnect™ with Brownout Detection
    * Vertical Pin configuration
    * Red LED indicates number of holds
Specs:
    * Type:Microlite Park Flyer Receiver
    * # of Channels:6
    * Modulation:DSM2
    * Band:2.4GHz
    * Dimensions (WxLxH):18.85 x 25 x 11.6mm
    * Weight:3.35 g
    * Voltage Range:Input: 3.5–9.6V
Odg: Novi Spektrum parkflyer prijemnici - 6110 serija
Zašto samo za Parkflyere?
Jel zbog snage serva koji se koriste kod parkflyera odnosno ograničene (manje) snage (struje)?
Ne, zbog dometa.
Kod ovih malih prijemnika moze doci do zasjenjenja tj. gubitka signala.
Zato svi oni veci, full range, imaju i male satelite tak da hvataju signal "od svuda".
