Topic: HK buddy code popusti (Read 304171 times) previous topic - next topic
Odg: HK buddy code popusti
Reply #120
3660SL 3060kv Brushless Inrunner (WaterCooled) - http://www.hobbyking.com/buddy.asp?code=BF5D5958-0820-49B7-8535-11029A4E831A
Servo Mount - http://www.hobbyking.com/buddy.asp?code=815058CE-FA16-436F-93C1-2F2B14E4DC37
Antenna Mount - http://www.hobbyking.com/buddy.asp?code=3A9FFA41-C5FA-4869-946E-53D5A11C0C90
Water Cooling Motor Mount 30mm - http://www.hobbyking.com/buddy.asp?code=40F4E689-6362-4FA4-B886-34139337406F
Shaft Adapter - 5mm motor shaft to 5mm Flexi Shaft - http://www.hobbyking.com/buddy.asp?code=797873D8-AD83-4F18-BFE0-D05716D13DD9
Water Outlet - http://www.hobbyking.com/buddy.asp?code=D6E3492D-E6EF-4BD3-944B-EA4F1AE20755
D933MG Digital Metal Gear Servo 2.0kg/ 12g/ 0.10sec - http://www.hobbyking.com/buddy.asp?code=D4751104-7DB7-46C6-9D1D-95F57918D66B
Control Rod/ABS Sleeve (1pc/bag) - http://www.hobbyking.com/buddy.asp?code=C93CC75B-5DBE-4DD0-8480-57D9C46A5445
Flex-Rod Boots - http://www.hobbyking.com/buddy.asp?code=7E457E35-7A79-4ECE-88C9-F82BDB9C5C18
Turnigy Heat Shrink Tube 30mm Black (1mtr) - http://www.hobbyking.com/buddy.asp?code=ED67365A-48F8-44F0-A69B-CBD792D70F68
Turnigy Long Shaft 4pc Hex driver set - http://www.hobbyking.com/buddy.asp?code=598E2010-A9AB-4E2B-B25C-1B34D39F8744
TURNIGY Voltage Protector - http://www.hobbyking.com/buddy.asp?code=C830B608-E7E6-4D93-904A-86CB81D627D3
Plastic Pin Horn (10pcs) - http://www.hobbyking.com/buddy.asp?code=B9D7F9D6-C595-43DF-9846-62AB37230CEE
CA Applicator Fine #322 (1pc) - http://www.hobbyking.com/buddy.asp?code=6B5CD8A3-09C5-450E-B20B-4FEC264D0E21
Fiberglass Canopy for Trex-450 - http://www.hobbyking.com/buddy.asp?code=79FC4866-A2E1-47F9-A138-77995EA47837
Vrijedi do 18.10.
Reply #123
Reply #125
ZIPPY Flightmax 800mAh 2S1P 20C 1.83$ popust
http://www.hobbyking.com/buddy.asp?code=40876454-F715-41C2-AA82-CD625F9C038D
Turnigy Type D Light Wood propeller 11x7
http://www.hobbyking.com/buddy.asp?code=4D3E89F7-17A6-41D4-A4C6-DDDA6C9A456E
Master Airscrew propeller 12x5
http://www.hobbyking.com/buddy.asp?code=7CF3EA50-094B-4288-B1D4-02CF8FC19A25
Spinner 45diam / 5mm shaft
http://www.hobbyking.com/buddy.asp?code=ABE7F9BB-9259-4665-9B93-386C49A64E8D
TURNIGY Plush 40amp Speed Controller 2$ popust
http://www.hobbyking.com/buddy.asp?code=67BC2232-C28C-427E-B76E-6F2B81F036C2
3.5mm 3 wire Bullet-connector for motor (5pairs)
http://www.hobbyking.com/buddy.asp?code=AE9782BC-FFA1-499F-BE26-26AE51311DCF
Super Light Wheel D65xH18.5 (3pcs/bag)
http://www.hobbyking.com/buddy.asp?code=6CD8A5D7-0C00-4F64-90CF-2C967B3BD42F
Light Plane Plastic Part set (10pcs)
http://www.hobbyking.com/buddy.asp?code=8CF3E9C2-1FD1-4656-9D52-0F22D8E3D289
Super Light Hinges 26x20x.5mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=ADB3C625-6FD8-47A1-BC2C-0FD96B42D759
Nylon Clevis 2x29mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=13B8A2FA-6DA9-4417-9E99-54BD933CED5F
Pin Horns L20xW15xH11.52 (4 holes) 10pcs/set
http://www.hobbyking.com/buddy.asp?code=53507BDD-CF9D-4558-BCB7-EA433CCDFB39
Nylon & Pinned Hinge 16x28.5 (10pcs)
http://www.hobbyking.com/buddy.asp?code=A8F27594-E2FD-4FFC-A1F5-BE267D35F5D2
C-Clip Ring Plier 4 in 1 set
http://www.hobbyking.com/buddy.asp?code=72A5AAA8-69EB-4020-8DFB-5B4E5CBC6451
TL-262 Thread Locker & Sealant High Strength
http://www.hobbyking.com/buddy.asp?code=9B939253-68E1-4890-B56E-6FD88A0B57BF
H35 Standoff Motor Mount
http://www.hobbyking.com/buddy.asp?code=59DF8BC7-1007-4C77-989F-0A2379C85DAF
XR Type B Beechwood 3D/SF Propeller 10x5
http://www.hobbyking.com/buddy.asp?code=2D05D8A9-02A2-43E5-B8EB-443819E45A79
Cherry wood 11x4 propeller
http://www.hobbyking.com/buddy.asp?code=8F92F2BC-C99F-4A6A-8B4F-073FFF7E5C4C
Turnigy Ultra-light wood propeller 10x6
http://www.hobbyking.com/buddy.asp?code=482E87B9-5C6A-4DD7-B650-C119E244C9AB
Wire Mesh Guard Yellow 10mm (1mtr)
http://www.hobbyking.com/buddy.asp?code=AC414B88-E908-4F2B-A259-D1C33E4937BE
Wire Mesh Guard Yellow 6mm (1mtr)
http://www.hobbyking.com/buddy.asp?code=741EC323-5F6D-4C22-AF5F-B19CB236FCAE
Turnigy 760LV-HV Dual Pulse Width Selectable Servo Tester 4.32$ popust
http://www.hobbyking.com/buddy.asp?code=CEABB789-204F-4F4C-BF5C-A0E2BFC95E0B
Reply #127
Daj molim te javi kakvi su ovi TurboThumbs za Futabu, meni se na ovima stock stalno kližu palčevi...
Reply #128
Reply #129
nemaš beda, javim ti.
stock stickovi su mi bili skliski, onda sam kupio slične samo cnc sa ostrim gripovima, ok su za sport fly ali sada nailazim na problem dok vježbam 3d jer osim što mi palci budu izbodeni skliznu mi kada izmjenično počnem lupati jače 3d manevere stoga moram uzeti ove turbo thumb jer imaju krune od 12mm i kažu da je totalno "fly in" feeling, veća kontrola i nema klizanja.
LP
InnovationMatters
Reply #131
Find my codes here: http://hk.rc-international.info/swarm/sinaptix (valid until November 02, 2011)
Code: [Select]
[URL=http://www.hobbyking.com/buddy.asp?code=E3ACA93A-BF56-47CC-994B-98D1F561860E]Push Rod Sleeves (2pc/bag)[/URL]                                       Save US$: 0.44
[URL=http://www.hobbyking.com/buddy.asp?code=896A6FF4-D965-4084-9B89-F62D4C025567]Maxi-Cure Extra Thick CA 2. oz[/URL]                                   Save US$: 7.69
[URL=http://www.hobbyking.com/buddy.asp?code=39F614A1-438B-44A3-AAE0-9A0DD3861DA4]Nylon Arms 2x6x7.5mm (10pcs)[/URL]                                     Save US$: 0.61
[URL=http://www.hobbyking.com/buddy.asp?code=931BF938-4EC5-4F1B-80BB-6ECA05F995B8]Blind Nut M6 (10pcs)[/URL]                                             Save US$: 0.44
[URL=http://www.hobbyking.com/buddy.asp?code=C91B6744-95BF-4C2C-AB6E-9B7DBEA2BC89]Blind Nut M2 size (10pcs)[/URL]                                        Save US$: 0.25
[URL=http://www.hobbyking.com/buddy.asp?code=987760DD-1A5B-43C8-AF34-25AFA19F3269]Push Rod Sleeves (2pc/bag)[/URL]                                       Save US$: 0.44
