Topic: HK buddy code popusti (Read 302455 times) previous topic - next topic
Odg: HK buddy code popusti
Reply #271
Reply #272
Evo i od mene do 28.05.2012, jel zna kako ovo funkcionira, jel ide i ko kupuje i čiji je buddy code dobivaju nešto?
Battery Tape 150mm (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code=C424FDBD-891E-4E0F-BEC2-C45268955E23
Nylon T-Connectors Male (10pcs/Bag)
http://www.hobbyking.com/buddy.asp?code=02FAA21A-2F44-4B0B-8E24-9355030E8717
Nylon T-Connectors Female (10pcs/Bag)
http://www.hobbyking.com/buddy.asp?code=50FE126C-13EE-469F-8CED-53B6AA305061
Flat 26AWG servo wire 1mtr (R/B/W)
http://www.hobbyking.com/buddy.asp?code=2BF5BC0F-C0B0-4BFC-A2FC-0A5264095EB7
Receiver Switch
http://www.hobbyking.com/buddy.asp?code=1542DA53-80B5-45DE-900F-37CA23A17A57
40CM Servo Lead (Futaba) 32AWG Ultra Light
http://www.hobbyking.com/buddy.asp?code=64F880B5-930F-4FA9-A347-8FCF204F3DB2
JR Y Servo Lead 15CM Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code=450D5232-C072-4AF6-AF2E-AC288DBB2611
Turnigy 5mm Heat Shrink Tube - RED
http://www.hobbyking.com/buddy.asp?code=F6A33ED2-68E7-44A6-8852-A842DF5D4467
Turnigy 4mm Heat Shrink Tube - RED (1
http://www.hobbyking.com/buddy.asp?code=2FEADDAA-FEF9-4701-815B-97A5FE8ACDD2
Turnigy 3mm Heat Shrink Tube - RED (1
http://www.hobbyking.com/buddy.asp?code=E91759F3-9037-4574-9D45-E5CF0C37266F
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?code=7E58C497-FAE8-4B8B-A917-34A376EA1CD3
Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?code=2387C3A9-1007-4564-95A7-1CDDBD4BC1F8
Turnigy 3mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?code=B49DF94E-D511-4144-8600-E07F9C4406F8
Control Horns 16x20mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=1D6B7E39-0561-43CF-AC48-6CEC82FC3064
Pin Horns L20xW15xH11.52 (4 holes) 10pcs/set
http://www.hobbyking.com/buddy.asp?code=7E9EB1F8-D879-4D75-81B4-E0E4636288E5
Nylon Clevis 2x29mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=4D9F8964-98BD-4A7C-BE8B-115D61D3449C
Nylon Clevis 1.8x27mm (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=C169F64E-63FF-41D9-911E-C101EB24C27E
AC Hinge L25*W20*H0.3 (10pcs)
http://www.hobbyking.com/buddy.asp?code=382856D4-0ED7-467C-BF91-2FCEA166186F
Alloy Clevis for Non Threaded 2mm Control Ro
http://www.hobbyking.com/buddy.asp?code=A0A9E2FF-3546-4402-BDD4-4647A731F02A
Pivot & Round Hinges 2x33 (10pcs)
http://www.hobbyking.com/buddy.asp?code=55E08B78-E152-46BA-96AC-2C2930ECDC4C
Linkage Stopper D1.8mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=EDAAEF21-D0D0-4470-9D95-F27997C5A1D4
Pivot & Round Hinges 2.5x48 (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=C72FC347-2B57-44CB-AF58-CAFFA0C26C08
Pivot & Round Hinges 4.5x67mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=8AF8EA78-86BF-40E9-9F56-ACDE7CC7C7DB
Nylon Screw 6x30mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=C7E4ED97-4776-497D-8C7F-AA26FB3EAB4B
Micro Hinges 23x7x3mm (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=5F73CE4C-6461-4415-BA66-2A5C386FE8FF
Adjustable Control Horn 3x24mm (5sets)
http://www.hobbyking.com/buddy.asp?code=94C9539F-8731-49AF-B787-15CB8BD9C490
Nylon Clevis M3 L27 (10pcs)
http://www.hobbyking.com/buddy.asp?code=3C1F1170-58DE-4DA0-99A3-59FFE974FB13
Nylon Clevis 1.0x34mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=D9F06CA0-176B-4B68-9262-A79CED0EE476
Nylon Screws 6.25x55mm (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=8F4D9E39-2438-42A4-AB53-A87B9CB511DF
Adjustable Control Horn 3x34mm (5sets)
http://www.hobbyking.com/buddy.asp?code=D3CD236F-1E2E-467C-AD21-F279D090A8CD
Micro Clevis 1.2x22mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=2EF7CC2D-0FF0-4EF5-9380-7D0B6E4837EF
Horn X-Large w/ Clevis 40x30mm and eyelet (5
http://www.hobbyking.com/buddy.asp?code=8A3A717B-ACE4-401A-8529-F2AACDFE2BC8
Steel Axles D4 x L57 mm x M5 (5pc)
http://www.hobbyking.com/buddy.asp?code=4E2FEEB0-E898-49B2-821A-F101B704C1A8
Landing Gear Wheel Stop Set Collar 6x5.1mm (
http://www.hobbyking.com/buddy.asp?code=2E445303-9D7C-44B1-9E1A-DCB0F7799D8B
Grub Screw Set M3x4 10 Pack
http://www.hobbyking.com/buddy.asp?code=2C955115-D336-4EA7-BE27-49EFE175E2FB
Hex locknuts M3 10pc
http://www.hobbyking.com/buddy.asp?code=809DC965-29CA-45E4-B8AD-7039E28C31C4
Nylon Screws - Diam:4 x Length:34mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=7E5442DB-3C37-4448-BC9F-D39763E09E0C
Cyanoacrylate (Super Glue) Single Pack
http://www.hobbyking.com/buddy.asp?code=F91FE7A3-4F14-4B1F-A9C5-0C12C5C969FE
Elevator Shaft
http://www.hobbyking.com/buddy.asp?code=BEA92354-E57F-4C64-92ED-B1D3F2F3D42D
Propeller Adapter (Colet Type) 3MM
http://www.hobbyking.com/buddy.asp?code=94FB9533-0BBF-4E9A-BCF5-3D730DF4F550
Silicon fuel pipe (1 mtr) Yellow for Gas/Nit
http://www.hobbyking.com/buddy.asp?code=5DEC0813-43D4-4E6F-8CBC-0890704E8E16
Silicon fuel pipe (1 mtr) White for Nitro En
http://www.hobbyking.com/buddy.asp?code=48647085-BCD0-40C3-BFDC-802E6F0BA480
Fuel Pipe plugs D4.5xd7xH13mm
http://www.hobbyking.com/buddy.asp?code=38E426FC-808E-4CDA-AF90-29A3341E4489
Turnigy Compact Re-buildable Fuel Filter
http://www.hobbyking.com/buddy.asp?code=AEA26BEE-40CF-441A-AAD0-7E5361AC31C2
Folding Propeller Assembly 9.5x8 (Alloy Hub/
http://www.hobbyking.com/buddy.asp?code=AE8F3F78-B6CA-41D2-A8BD-CA54FC97877A
One Way Air Refill Valve
http://www.hobbyking.com/buddy.asp?code=3919F459-0C62-4C21-9638-A7983A351517
Eagle for Vertical Stabilizer Left & Right S
http://www.hobbyking.com/buddy.asp?code=AFCD09E7-135C-4341-9DAB-2946BB0C8BD3
Dragon Fighter Decal Sheet Large 445mmx300mm
http://www.hobbyking.com/buddy.asp?code=FB3AC380-FF13-44BA-B150-79ECAD154014
US Navy Eagle Left & Right Hand
http://www.hobbyking.com/buddy.asp?code=C61CEDDD-94BC-4EE8-850C-0CE445C05DA8
Luftwaffe 0.60~0.90 size Sheet B
http://www.hobbyking.com/buddy.asp?code=6C436B82-C012-4F7A-9A05-4BE3BAED397C
EC3 plug Male 14awg 10cm
http://www.hobbyking.com/buddy.asp?code=515B4AF1-78B4-45EA-A432-0FDB40285D98
Multi Coloured Flashing 5mm LED with 1m Wire
http://www.hobbyking.com/buddy.asp?code=79ACA82B-A107-45C0-9AA9-173E2CF15859
Necu zvake, vrati kusur
Team LAHOR
Reply #273
jos dve tri ovakve narudzbe i hrvati ce im isprazniti ducan  :D :D
morat ce oni tu poslovnicu otvoriti izgleda  :)
Reply #274
a bogme koliko sam stavki spržio tu ti je to negdje :D
Team LAHOR
Reply #275
Reply #277
Reply #280
[move]safe 0.36$[/move]
http://www.hobbyking.com/buddy.asp?code=1BAA21EE-D788-474D-B1C9-3B5EF12FC7D9
Turnigy High Density R/C LED Flexible Strip
[move]safe 0.42 $[/move]
http://www.hobbyking.com/buddy.asp?code=9F82ED12-6377-4120-BF37-6C3C4CB16CCE
Reply #282
Hvala Moriaty, odlično mi sjelo na konto, uzeo odmah Red Brick i još par sitnica, platio samo shipping !  ;)
Reply #283
kakav je taj red brick? Iskustva?
