Topic: HK buddy code popusti (Read 301380 times) previous topic - next topic
Odg: HK buddy code popusti
Reply #375
Evo i od mene nešta :)
Find my codes here: http://hk.rc-international.info/swarm/el-force (valid until November 01, 2012)
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Black) Save US$: 1.40
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Red) Save US$: 1.80
Bumper Mount (1Set/Bag) - A2016T                  Save US$: 0.75
Steering Linkage - A2016T                         Save US$: 0.14
Hobbyking X-Car 45A Brushless Car ESC (sensored/sensorless) Save US$: 3.62
Long Heavy Duty Body Clips (Purple) (10Pcs)       Save US$: 2.69
Polyester Hook and Loop Velcro V-STRONG (1mtr)    Save US$: 0.27
Super Light Pivot and Round Hinges D2xW8xL24mm (12pcs) Save US$: 0.50
Mini Ultra-light Horns 23x14x6mm (4pcs/set)       Save US$: 0.27
Turnigy 4mm Heat Shrink Tube -                    Save US$: 0.31
Turnigy 3mm Heat Shrink Tube - BLACK (1mtr)       Save US$: 0.31
Control Horns 13.5x16mm (10pcs)                   Save US$: 0.36
Turnigy Heat Shrink Tube 50mm Blue (1mtr)         Save US$: 0.50
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)       Save US$: 0.31
2.4Ghz A-FHSS Compatible 8CH Receiver (Hitec Minima compatible) Save US$: 3.01
HobbyKing Super Glue CA (50g / 1.7oz)             Save US$: 1.32
Pin Horns L22xW19xH.9 (10sets)                    Save US$: 0.36
Tyres (1Pair/Bag) - A2016T                        Save US$: 3.13
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
Reply #378
Evo malo i od mene: Vrijede 14dana od 26.10.2012
USB Simulator Cable XTR/AeroFly/FMS
http://www.hobbyking.com/buddy.asp?code=67E0ACF0-3718-4552-8F93-C85E89B9FF3A
Turnigy balancer & Charger 2S-3S
http://www.hobbyking.com/buddy.asp?code=DBA4CACC-AAA1-4679-AE20-260D0F6464C3
HK15148 Analog Servo 17g / 2.5kg / 0.14s
http://www.hobbyking.com/buddy.asp?code=38910CAF-7003-4863-A5EC-AB3777B38C47
Male XT60 connectors (5pcs/bag) GENUINE
http://www.hobbyking.com/buddy.asp?code=86BDA949-CB40-4023-AD3A-8D20C6408633
Control Horns 16x20mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=4716E9AC-70BE-40D1-900C-FD0AEC1BF4C6
Nylon Clevis 1.8x27mm (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=4BAC4703-5B61-4DCA-9E5B-4B993E9D0ED1
Nylon Snap-Click style clevis 2x8x23mm (10pc
http://www.hobbyking.com/buddy.asp?code=EBDD924F-7C22-43CB-82E0-A1997FF3898D
Strong Rare-Earth Button Magnets (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=2C31DA12-E777-48F9-83A2-F10A2146FE72
SF E-Prop 7x4 / 178x102mm w/ Adapters Black
http://www.hobbyking.com/buddy.asp?code=72966F16-23E2-457F-BA17-B456CF83AB54
12 LED Cluster - BLUE
http://www.hobbyking.com/buddy.asp?code=F30D74C5-45DD-454A-AD8F-80A73F3E82F4
LED Strip with JST Connector 200mm (Blue)
http://www.hobbyking.com/buddy.asp?code=85C70B20-8FF3-4819-AAAC-A0B8D31809DB
LED Strip with JST Connector 200mm (Red)
http://www.hobbyking.com/buddy.asp?code=DD10AC87-1DD2-4EB8-B9C1-C01D93F7CF8B
Prop Saver w/ Band 3mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=BBB22CB0-1313-4B20-9DA0-B31D38D22961
Reply #381
Nema više buddy code-a za modul, HK ukinuo ;)
I ovako je povoljno.
Reply #383
Find my codes here: http://hk.rc-international.info/swarm/varadero (valid until November 14, 2012)
AX 1806N 2100kv Brushless Micro Motor (19g)       Save US$: 0.89
5030R (green) Three Blade Propeller (ABS) (3pc)   Save US$: 0.21
5030 (green) Three Blade Propeller (ABS) (3pc)    Save US$: 0.31
Nylon and Pinned Hinge 16x28.5 (10pcs)            Save US$: 0.37
Reply #384
Ekipo, ispricavam se na glupom pitanju.
Ja kupih Turnigy stanicu na HK ali ne vidim gdje bih mogao kliknuti da saznam 'buddycode'. Moze pomoc ?
Reply #385
nema kodova za sve proizvode, pa tako ni stanicu
Reply #386
Ok, hvala na odgovoru, ali da ima, gdje bih vidio taj kod  :-[
Reply #388
Reply #389
