Topic: HK buddy code popusti (Read 304154 times) previous topic - next topic
Odg: HK buddy code popusti
Reply #79
Nešto za helije 250, 450:
vrijedi do 12.8. ako se ne varam:
250 class Fiberglass Main Blade 205mm http://www.hobbyking.com/buddy.asp?code=39D30A56-C3AC-48EB-8C5F-58FFBD50C35C
TIG 325mm Carbon Fiber Blade  http://www.hobbyking.com/buddy.asp?code=F3D86897-D959-4A21-8F7B-E84BE350F9F3
Thrust Bearing 3x8x3.5mm (2pcs/bag)  http://www.hobbyking.com/buddy.asp?code=CB9CA626-BDCF-4F88-B38D-E26C096D0F75
HK-450 Metal Tail Rotor Shaft upgrade versio   http://www.hobbyking.com/buddy.asp?code=A4464AA0-BC13-45DE-B594-506E8499C85E
Bearing for Main shaft Part # F045  http://www.hobbyking.com/buddy.asp?code=22279156-425C-43D8-B23B-14D5DB32AAD8
HK-250GT Tail Drive Gear Shaft (2pcs/set)  http://www.hobbyking.com/buddy.asp?code=534EC1A1-F238-446C-9449-0AA129CF8CA2
HK-250GT Tail Boom  http://www.hobbyking.com/buddy.asp?code=351BA7DC-673B-415E-8FFD-C8771FCD0690
HK-250GT Main Shaft (3pcs/set)  http://www.hobbyking.com/buddy.asp?code=BD6F28B0-FA94-470E-B13B-3141ADA15D71
HK-250GT Stabilizer Blade  http://www.hobbyking.com/buddy.asp?code=B3B2A342-CF81-408A-A301-1C68EB70683C
HK450V2 Tail Rotor Control Set  http://www.hobbyking.com/buddy.asp?code=D745D49B-2785-465B-8B3E-27737501F3FF
GT450PRO Tail Rotor Control Set  http://www.hobbyking.com/buddy.asp?code=6F4A0BFF-D3E6-401B-ABBF-7016AABF9314
Main Rotor Blade Assembly Tool (5mm)  http://www.hobbyking.com/buddy.asp?code=1D4194A5-7A80-4972-9D34-76372476D4C1
Male XT60 connectors (5pcs/bag) GENUINE  http://www.hobbyking.com/buddy.asp?code=1D7E9B70-124C-49A6-B5FB-D59958A44462
Reply #82
Reply #86
do 23.8.2011.
Turnigy 2mm Heat Shrink Tube - BLACK (1mtr)
91% Save US$: 0.21
Turnigy 2mm Heat Shrink Tube - RED (1mtr)
91% Save US$: 0.21
Turnigy Pure-Silicone Wire 20AWG (1mtr) RED
72% Save US$: 0.31
Turnigy Pure-Silicone Wire 20AWG (1mtr) Black
72%  Save US$: 0.31
On Board Lipoly Low Voltage Alarm (2s~4s)
 Save US$: 0.96
HXT 4mm to XT-60 Battery Adapter (2pcs/bag)
30% Save US$: 0.76
Wire Mesh Guard Black 6mm (1mtr)
60% Save US$: 0.27
Reply #87
Reply #88
Reply #89
Non-Adhesive Velcro (2pc/bag)                                    Save US$: 0.37
Turnigy Pure-Silicone Wire 18AWG (1mtr) Red                      Save US$: 0.79
Turnigy Pure-Silicone Wire 18AWG (1mtr) Black                      Save US$: 0.79
Turnigy Heat Shrink Tube 10mm BLACK (1mtr)                       Save US$: 0.55
Battery Strap (5pcs/bag)                                         Save US$: 0.09
ZIPPY Flightmax 4000mAh 3S1P 40C                                 Save US$: 0.90
