Topic: HK buddy code popusti (Read 304564 times) previous topic - next topic
Odg: HK buddy code popusti
Reply #90
valid until August 29, 2011
Solo Pro FP II Fixed Pin Balance Bar                             Save US$: 0.06
Solo Pro FP II Swashplate Set                                    Save US$: 0.13
Turnigy Pure-Silicone Wire 18AWG (1mtr) Red                      Save US$: 0.79
Solo Pro FP II Bearing Set                                       Save US$: 0.21
TURNIGY Voltage Protector                                        Save US$: 1.38
Reply #91
Eto i moje narudzbe... pa ako neko teba...do 28.08
        Linkage Stopper M3x2xL11.2mm (10pcs/set) - http://www.hobbyking.com/buddy.asp?code=5D3CF5AC-8CF4-47CA-8451-3CAF3341132F
    Landing Gear Wheel Stop Set Collar 9x4.1mm - http://www.hobbyking.com/buddy.asp?code=330752C5-6972-4182-BF7B-0B2236F72513
    Nylon & Pinned Hinge 16x28.5 (10pcs) - http://www.hobbyking.com/buddy.asp?code=E4CD4A07-5E6F-446B-A3FA-807BEE24C622
    Nylon & Pinned Hinge 20x36 (10pcs) - http://www.hobbyking.com/buddy.asp?code=6B4878F9-8FD1-4C4E-9D07-F38A42DB45C2
    Linkage Stopper D2.1mm (10sets) - http://www.hobbyking.com/buddy.asp?code=F5765BED-5FCB-45EA-886B-C8AD22EBBE1E
    Nylon Clevis M2 L23 (10sets) - http://www.hobbyking.com/buddy.asp?code=7DC0189F-A085-4E3A-B1D2-E6C5BFE7421C
    Front Wheel Steering Arm & Mount Set 40mm - http://www.hobbyking.com/buddy.asp?code=5646810D-7FF6-49ED-ADD6-59F221EF5D0C
    Steering Arms (Fullarm) 10x40mm (5pcs) - http://www.hobbyking.com/buddy.asp?code=20B5AE8D-45E1-456C-A422-F99681B06DA1
        Master Airscrew propeller 12x5 - http://www.hobbyking.com/buddy.asp?code=A9FC1E74-736E-4A03-A03E-3281E1A8C993
    Master Airscrew propeller 12x6 - http://www.hobbyking.com/buddy.asp?code=3ED34B65-A5F5-4A28-BCAC-64209F266220
    HobbyKing 1500mAH LiFe 3S 9.9v Transmitter  - http://www.hobbyking.com/buddy.asp?code=3816D525-AD57-478F-8D5E-F60C98590BFB
    Temperature Sensor w/ Futaba plug    - http://www.hobbyking.com/buddy.asp?code=2E12ACE3-81DE-4B98-8F93-A1632B8E3504
    450 class Fiberglass Main Blade 325mm - http://www.hobbyking.com/buddy.asp?code=AEFF6514-6571-4ADD-ACF3-6F55ED4FED78
    Carbon Fiber Tail Blade 68mm - http://www.hobbyking.com/buddy.asp?code=58014550-62AD-4553-9073-FBBCEB12CB06
   D933MG Digital Metal Gear Servo 2.0kg/ 12g/ - http://www.hobbyking.com/buddy.asp?code=E86D4804-5E77-4CE8-8D91-A5EDFD088453
    Pinion Gear 3mm/0.5M 11T (1pc) - http://www.hobbyking.com/buddy.asp?code=97B5EAE7-874C-418F-BCE6-6E54116447F9
    Pinion Gear 3mm/0.5M 12T (1pc) - http://www.hobbyking.com/buddy.asp?code=12C81E24-9552-42EE-83D9-69A17F4BA3CC
    Pinion Gear 3mm/0.5M 13T (1pc) - http://www.hobbyking.com/buddy.asp?code=F303B492-D0F4-4DCF-B761-9700D60E3CD3
    Turnigy nano-tech 2650mah 3S 35~70C Lipo Pac  - http://www.hobbyking.com/buddy.asp?code=60A387D8-60AF-4B1F-AF8A-9C0C168CF34D
    TURNIGY TRUST 55A SBEC Brushless Speed  - http://www.hobbyking.com/buddy.asp?code=6378181B-93B9-4732-8DA5-4A5871C53780
    PLUG-KING Multi-19 Mega Charge Plug Ada - http://www.hobbyking.com/buddy.asp?code=4B905DBB-AB94-4C87-9BA3-DCB93A6FB0BB
    Turnigy Typhoon 450H 2218H Heli Motor http://www.hobbyking.com/buddy.asp?code=B385A3F8-14C7-40FC-B397-EFC83234CF93
    GT450PRO Servo Linkage Set - http://www.hobbyking.com/buddy.asp?code=24F4E36A-2F82-4B22-9F39-50EFA6D391F1
    Twelve 2-56 Gold-N-Clevises - http://www.hobbyking.com/buddy.asp?code=0A83DD0B-CFDE-498C-9434-71DAFDD79444
    M3 Steel Linkage Ball for all helis (10pcs) - http://www.hobbyking.com/buddy.asp?code=7514CAC2-E00C-4152-B6D6-F47ABF70877C
    Pom Horns 20x27mm (10pcs/set) - http://www.hobbyking.com/buddy.asp?code=9FD93460-EC45-43AA-BB82-D46A57F4D6C1
    HK450V2 Timing Belt - http://www.hobbyking.com/buddy.asp?code=545C2084-C866-43CA-86EF-0E7499897412
Hell-i boy
Reply #94
Reply #97
Extra BuddyCodes, you can save 23.46% for all of this items with http://rc-buddy.com/user/
            Z-bend Pliers. Heavy Duty 90deg up to 1/16
            Savings:  23.46 % / $1.64
                PriceAfter:  $5.35
                Weight:  399 g
Reply #98
Hell-i boy
Reply #100
Reply #101
