Topic: GAUI 330X / 500X (Read 25520 times) previous topic - next topic
Odg: GAUI 330X / 500X
probaj pa vidi.
ovisi o tome koliko ga natovariš.
jer ako pukneš 5Ah batku gore, i kameru... ne znam hoće li i poletjeti uopće s 8'' na toj 3S što imaš  ;D
pošto je i teži a i motori mu se vrte nešto sporije nego na manjem bratu
no zato nabavi 4S batku pa kemijaj... ako ti je u cilju provjeriti pa da znaš što prodaješ.
ak nije, onda se drži onog što piše proizvođač, i letit će ko beba. a nek kupac kemija...
Probam pa javim  :)
da nelutam i gubm vrijeme, lakse mi pitat ovdje :d ima li njihov kontroler sta od senzora? ili je gol kao KK?
Uskoro nam dolazi GAUI GU-INS!!   :)
GAUI GU-INS supports X-type flying Quad-copter (GAUI 330X, 500X), it can be extended for use on Hexa-copter, Octo-copter etc…. (Please reference GAUI product version/optional purchase module).
OSD (On-screen display, optional purchase module) electronics can be connected to GU-INS, which provides precise data monitoring on altitude, distance, position, attitude and battery voltage.
Onboard USB interface connector for firmware update.
Interface provided to connect with standard receiver and JR satellite receiver.
Specifications:
1.   Dimensions - Main controller: 53.5 x 38.5 x 12mm
           GPS antenna: 42 x 34 x 15mm
Weight - Main controller: 27g (w/o cables ), GPS antenna: 23g (with cable)
2.   Frequency: 300Hz output to ESC
3.   Operating temperature: -20~80°C
4.   Operating modes: Rate (manual) mode, Auto balance mode, GPS positioning mode.
5.   Rate (manual) mode: Max angular velocity: 300 degree/sec
6.   Auto balance mode: Max tilt angle: 60 degree.
7.   GPS positioning mode:
a.   Hovering accuracy: Horizontal: ±1m, Vertical: ±0.5m
b.   Max yaw angular velocity: 250 degree/sec
c.   Max tilt angle: 45 degree.
d.   Max horizontal speed: 10 m/s,36 km/hr
e.   Max vertical speed: 8 m/s (horizontal posture)
8.   GU-INS provides pitch and rolls output signals, can work with different types of camera mounts.
9.   Fail-safe functions: Automatic Go-Home, Signal lost Go-Home, Low voltage protection.
10.   Suitable wind condition: < 10 m/s
Features:
1.   Easy to install and setup, no need of software on PC for adjustment.
2.   All functions can be setup & confirmed by LED lights indication.
3.   All in one design (combined inertial measurement unit and main controller) with simple cable wiring.
lijepo,
jesi li probao kako leti 500tka kroz 2 ova tjedna?
Jel zna netko kako napraviti takav luping??  :'(
misliš opčenito luping/valjak na quadu ili luping na FPV
razlike nema, dok god je quad sposoban za taj "manevar"  :)
ne znam kak je kod gaui-a ali kod drugih kontrolera samo daš full palicu u željenom smjeru  ;)
očito gaui ima nekaj za podešavanje, pa mu treba omogućiti/dozvoliti veću razliku u radu nasuprotnih motora...  recimo rc rate ili tak neka opcija isto pomaže....
recimo na MWC kontroleru samo sa rc rate opcijom mjenjaš broj okreta (lupinga ili valjka) u sekundi, ali time naravno jako dižeš osjetljivost na komande
uglavnom nađi opciju koja ti diže osjetljivost komandi, i diži ju postepeno dok ti model ne radi lupinge željenom brzinom, paralelno sa dizanjem osjetljivosti diži expo opciju na kontroleru ili stanici tak da ti model ostane upravljiv u hooveru
Na samom kontroleru se može podešavati samo gain
Misliš da bi ga trebao smanjiti?
Kad mu dam na primjer ful naprijed, postavi se okomito i odleti horizontalno
Nikada mi ni malo nije pokazao želju da ode prema lupingu
Kod naglog kočenja je ista stvar, postavi se okomito i stane, ali nikada ne ode preko okomice
taj kontroler ima akcelerometre?
ako ima, jedini način da napraviš luping je da ih isključiš jer oni ne dopuštaju nagib veći od 90 stupnjeva, bar je tak na MWC-u
prebaci onaj prekidač na kontroleru, koji je za prebacivanje između hovera za početnike i acro moda za napredne
te kod samog flipa moraš gas nabiti na pola, ne na ful, onda 2 motora mogu raditi na 100% a druga 2 na oko 30% npr
dok ako držiš na full gasu, razlika ne može biti tolika, jer kontroler recimo ograničava max izlaz na 90%
da ima još malo lufta za mijenjat potisak u svrhu stabilizacije...  pa  dva motora mogu ubrzati samo za 10%.
ugrubo ti govorim brojke, nisam mjerio na gauiu RPM metrom, samo da dobiješ ideju kako to radi.
kako je dex rekao, na naprednijim kontrolerima imaš postavke u kojima se to može precizno podešavati,
tu nažalost imaš samo gain koji odvijačem vrtiš.
a ne pomaže ni to što su motori sa slabijeg modela, s malim propovima te ogromnom batkom...
tu imaš video upute također:
mwc quad - stick video
malo sporije  ;D
http://tinyurl.com/flipslow
ja sam to malo vježbao pred god dana, nisam imao upute, išli smo na okladu može li se okrenuti  :D  ;D
http://tinyurl.com/rollquadtest
i ovaj http://tinyurl.com/roll2test
a vidim da nema acc, samo gyro.....
onda ej stvar više manje ista kao kod KK kontrolera
kod flipova nabijaš gasmalo ispod full oduzimaš gas na 1/3 i prilikom oduzimanja vučeš palicu full u željenu stranu...
držiš talicu tak dugo dok model ne napravi 270 stupnjeva kruga, puštaš palicu i dodaješ gas po potrebi da ga izvučeš......
to isto možeš raditi i na način da samo u hooveru daš full palicu u jednu stranu i držiš dok se ne okrene, ali u tom slučaju moraš imati puno prejake motore......
no takav način ne izgleda ni ne zvuči baš lijepo..... jer gubiš jako puno visine dok si naopak i velika je šansa da ga skršiš
Reply #43
Hvala puno, javim kako ide  :)
Uskoro ću staviti 500X pogon i 4S bateriju pa će biti snage
Reply #44
Ovaj mwc quad vozi tako da mu je jedan motor naprijed?
Možda je tako lakše?
