Topic: OSRC@Linux Power - nova generacija RC upravljanja (Read 18837 times) previous topic - next topic
Evo par detalja o uredjaju koji ce skoro na trziste, mislim da trenutno ne postoji ni jedna stanica koja ce joj biti konkurencija, nit po dizajnu a ni po specifikacijama, dovoljno je za pocetak reci da je range 10-40km, hrpa telemetrije ukljucena sa recimo live prikazom na google maps pozicija modela na njenom LCD-u ili prijenos video signala sa modela na isti LCD...40 kanala maximalno :D
Evo za pocetak par slikica i grafova i dio tehnickih detalja... ;)
Control UnitComputing   Communication   General
* ARM Cortex-A8 (OMAP 3503)   * RF Modem (10 - 40 KM range)   * 16 - 40 Channels (Or More)
* Clock: 600 MHz   * Bluetooth (If Overo Air)   * Self-actuated Sticks
* 256MB RAM, 256MB FLASH   * WiFi (If Overo Air)   * On-board Simulator in 3D
* Linux Custom UI   * GPS For Tracking And/Or UAV Control   * 2200 - 3300mAh Li-Po Battery
* 4.8" 800px x 480px Display   * Video Streaming directly to on-board screen   * Upgradable Switch or Pot
* MicroSD for Settings, Updates   * Two Way Telemetry & Sensor Communications   * Replaceable Stick to Stick
* Complete customization of the UI   * Default RC Module compatible   * Self Learning Features
* Display TouchScreen (Both displays)   * GSM Connectivity   * Internal Battery for Video Unit
* Removable Display (Optional)   * External GSM, RF, Video SMA Antenna Connectors   * Complicated Channel Mixing
* 2 x Camera Thumb Stick Controls
   * Thumb Sticks For Camera
* 11 x 2 & 3 Stage Switches
   * Over-All Width: 19.5cm
* 2 x Pot Trims
   * Over-All Length: 18.5cm
* 19 x Function Buttons
   * Over-All Depth: 5.78cm
* 128px x 64px Monochrome Display
   * Multiple Simultaneous Control
* Internal Speakers & Buzzer
Receiver Unit
* Microprocessor   * RF Modem (10 - 40 KM range)   * 16 - 40 Channels (Expandable)
* Custom Firmware   * GPS For Tracking And/Or UAV Control   * On-Board Servo Mixing
* MicroSD for Settings, Updates   * Two Way Telemetry communications   * Internal Accelerometers
* UAV Control (Optional)   * GSM Connectivity   * Internal Gyro
* Internal Video Transmitter (Optional)   * 9 Degrees of Freedom
Odg: OSRC@Linux Power - nova generacija RC upravljanja
Raspon cijene ce biti od 670-1220$  ;)
Tko ce raditi hardweraj za stanice?
kak bu to prošlo na HAKOMu ? :D
tomo treba ti jedno 7-8 dozvola i bude sve ok :)
flyfly mirage 2000
Do godinu dana prodajem auroru 9  :P
tzv, popis lijepih zelja...
Hm, Linux, aj lajk  :D A ne one šugave Futabe s Winblowsima, to nikad ne bih koristio
trenutni status izrade hardwera je ajmo reci na trazenju najboljeg proivodjaca, predani su svi detalji u par firmi koje se bave time pa ce se vidjet po kvaliteti izrade proto boarda i ostalih pizdarija ko ce biti sretnik za izradu
a ovi iz hakoma ce valjda svrsiti na ovo, ima samo 3 antene na sebi, u biti skidaju se dolje, dodju sa strane s njom  :D
uglavnom uredjaj je predviden za nadogradnju po zelji, stavis gore sta ti treba, poknes soft za to i idemo dalje, osnovna verzija dolazi sa ugradjenim rc linkom na freq oko 900MHz i jednim prijemnikom, sam rc link ce najvjerovatnije biti od onih španjolaca sta rade TK opremu za vojnu industriju
dobit cu tokom dana jos detalja pa okacim  ;)
pa to bu bilo ilegalno zbog frekve, što ne?
a i kak bu šljakalo uz sve GSM repetitore koji špricaju na toj frekvi?  onda bolje ubacite GSM modul pa vozite ko arosović na bonove.  ;)
odite još niže, kada već idete sub Ghz... ko Majk, na 433MHz,
on je oduševljen i dometom i izostankom kratkotrajnih failsafe aktivacija koje je imao na 2.4
(koje vidi nakon leta u memoriji MK octe, ne na oko, prekratko su trajale da bi model pao, ali ih je bilo)
nije nuzno da ce biti ilegala a sljakat ce isto ko i kad stavis 10 mobitela na hrpu, ne smetaju jedan drugome, kad stvar dobije CE i ostale certifikate onda nije ni ilegala za nas, uglavnom jos nije sve tocno definirano sta se tice izlazne freq a i opet postoji opcija da ubacis ono sta ti ogovara ili ono sta ti je recimo dozvoljeno;
evo jos koja slikica...
WOOOWWW, osim navedene performanse jako mi se sviđa dizajn stanice, fantastično =))
InnovationMatters
Bemti,pa morali bumo na fakultet za stanice da znamo sve to isprogramirati... ???
Spektrum DX8
ovo je brutala  :P
JR XP9303
Raptor 50 o.s. max 50sx-h
Raptor 30/50
No limit boat 54cc
U dolasku ostatak flote
a bit ce brutala definitivno
