Topic: esky 3S 20C baterija (Read 2271 times) previous topic - next topic
Odg: esky 3S 20C baterija
Ak je uspiješ smjestiti u stanicu i ako DX7 podržava do 12,6V napon  - da, radit će.
DX7 Lipo Conversion and Battery Alam Settings
podrzava
ali zasto prodaju na hk lipo namjenjene samo za stanice
koje kostaju 15 dolara a ima npr zippy za vec 9 dolara i "moguce" je dodat konektor i koristit je u stanici
This is not a standard lipo pack. It is a low discharge Lithium Polymer pack, designed specifically for R/C Radio use
copy/paste sa hk za bateriju koja je bas namijenjena za tx
koja je razlika obicne lipo i lipo za stanicu
 Turnigy Transmitter pack:
Its built with a low C-rate Long Life LiCo Formular which isnt like a standard LiPo
znaci nemoze se obicna lipo stavit u stanicu
ma moooože,
ali ove:
"This is not a standard lipo pack. It is a low discharge Lithium Polymer pack, designed specifically for R/C Radio use. We do not suggest you to use a standard Lipoly pack with Tx power plugs in your radio system as standard Lipoly are capable of a rapid energy release which can harm sensitive radio electronics.
Now you dont need to recharge your transmitter battery for months."
ili ti
struja pražnjenja je mala (u odnosu na standardne 20-35C) pa ti neće skurit stanicu u slučaju nečega  ::)
i drži napon mjesecima  ;D
skuzio sam da lipo koje su predvidjene za stanicu idu u stanicu ali nije preporucljivo "obicne" lipo stavlajt u stanicu
hvala bgnjip  ;)
