Topic: NAJBOLJI SERVO DO 10$ oko 10grama (Read 6396 times) previous topic - next topic
Pošto u zadnje vrijeme ima dosta prigovora na HXT900 molio bi prijedloge za najbolji all around servo do 10$ (+-).
Odg: NAJBOLJI SERVO DO 10$ oko 10grama
meni najdraži hitec HS82MG (u prosjeku se nađu od 16 - 20$)
i isti takav ali bez metalne getribe HS81 Price: $12.99
Neusporediv sas tim HTX-ima.
HS 55 također.  Price: $9.99
vidi servocity.com ;)
Kad zamjeniš htx-ove sa nekim od ovih serva, vidjet ćeš koliko to znači na modelu.
Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8303
ista sirina i duzina kao hx900 samo dublji tako da su pogodni za zamjenu a imaju metalnu getribu i jaci su,
cijena 7.69$
    22/05/2011
Enoch (62)
How the hell do these have a 5 star rating when all the top rated reviews show them to be an unreliable servo? Come one!
    TaMaster(11)
Don`t listen to these bad reviewer , me and all my club friends are using these on many 'heavy' EPO models and they work great!
This customer was awarded a credit for their answer.
    clickthepirate(5)
I have replaced the more expensive Hitec servos with the MG14 and they have worked flawlessly, I would not hesitate to recommend them to anyone needing a servos of this type and size.
    Gustavo(4)
Im using this servo on my HK 450 tail, and its never fail.
    vasy1(319)
Cuz they rule. I have not had any failires outside bad crashes. They just sing more compare to hxt900.
    Enoch(62)
Cheers everyone, glad to hear they're going well for you. Gives me a bit more confidence in ordering some. TaMaster, you got in first so you get the credit.
    merlind(9)
    jbc1234567(296)
I use these quite alot, for elevator and rudder and never had one fail on me yet. Fast response and centre well, what more do you need?
    SHANNON(1)
ive used these of sebart angel 30e, PA addiction which are large models. I have loads of throws on control surfaces and never had a problem.
These perform better than hitec hs-65 mg servos and a fifth of the price
    fiberglasser(19)
I haven't had a bad one yet. These are perfect for any 450 heli. They are fast, tight and have plenty of torque. Plus you can't beat the price!
    C.C.Rid3r(2)
I use this servo on Reactor bipe Electrifly , runs very well .Nice servo.
ja imam mg 14 na spa3dt i rade savrseno. imao sam dva na elevatoru na mini hypeu (ima razdvojen elevator), ali imaju premali hod pa sam presao na jedan standard servo na kojeg su celicnom zicom spojene obje strane elevatora.  imaju manu da im se raspada kuciste, vijci se razlohaju s vremenom. to sam sredio tako da sam stavio ca ljepila u svaki navoj i po rubu gdje se spaja kuciste.
dobri su i ovi sto wora veli, a meni su dobri i ovi: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10344 iako ih koristim samo za gas na nitracima.
polako napustam hxt900
Malo sam trazio spominju da Corona treba vise struje, i mene zanima alternativa hx900 (jos koji dobar 9g servo)
Quote:
Originally Posted by Sagittarius
I tested all aforementioned digital servos for my local heli club and would like to share my feelings with you.
CORONA DS928BB
Pro:
Good centering
it has the highest torque among the three I tested. 1.8kg listed torque is not exaggerated.
Work well with Futaba GY401 DS mode
All plastic parts are very well molded. No coarse feeling
Con:
Servo travelling is not so smooth.
Slight jitters though will not interfer the overall flying performance
Heat up quickly
Servo arm is not so strong
I ordered two Corona DS 928BB from United Hobbies - and I am not impressed. Apart from being heavier than claimed (11.0g without servo arm), they consume approx. 300mA moving slowly without any load (max. current approx. 750mA@5V). No wonder they heat up quickly, as they are very inefficient.
Warning: If you are flying with BEC - check what kind of continuous current your system can support. These Corona servos consume several times the current of comparable servos.
CORONA DS928BB
Ali link je bio na analogni dakle CS 928, ovaj je review za DS 928  ;)
Znači kužimo se. Ja ih imam nekoliko (analognih 928)  doma u rezervi, te jedan par ugrađen u najnoviji Piper koji još nije letio, tako da i nisam neka preporuka >:(
Što se struje tiče, ovi bi po reviewima trebali trošiti (dosta) manje od HXT 900.
Ali te ocjene na HK-u su jedno, a stvarnost drugo. Na HK-u gotovo da nema loših ocjena manjeg brata HXT-500, a u praksi od tri naručena jedan ne radi uopće, a ostala dva različito jedan od drugoga. Tako da,  review čitaj a kolegu pitaj  :D
Slažem se, ti reviewi na hK su nepouzdani, više vjerujem kada poznajem osobu. Svjetski prvak u baljezganju je moj vršnjak sa rcmodelreviews.com, e što taj trkelja, svaki puta kada nešto novo 'izađe' , dopisujemo se komentiramo uz smijeh. Njegov čuveni 'review':  http://www.rcmodelreviews.com/ds538mg_review.shtml
..tip likuje da je pronašao servo sa feleričnim zupčanikom... pri tome nije primijetio da taj servo ima deadband 10 mikrosec... (imam ih, pa znam pouzdano)  :D .
Dosta OT, da se vratim topicu:
- u klasi do 3$ najbolji svakako Corona 928
-u klasi do 10$, što i jeste ovaj topic, svakako GWS:
  http://www.hobbyking.com/hobbyking/store/%5F%5F4369%5F%5FNaro%5FHP%5FBB%5FServo%5Fw%5FFutaba%5FPlug%5F10g%5F10sec%5F1%5F7kg.html
 ili malo jeftiniji :
http://www.hobbyking.com/hobbyking/store/%5F%5F4370%5F%5FNaro%5FFH%5FBB%5FServo%5Fw%5FFutaba%5FPlug%5F10g%5F10sec%5F1%5F7kg.html
Navedene sam isprobao.
Slijedeće nisam isprobao, ali pročitao hvalospjeve (ne od Briana  :D )
http://www.hobbyking.com/hobbyking/store/%5F%5F6812%5F%5FMKS%5FS301%5FFET%5FMicro%5FServo%5F7%5F98g.html
i ovaj:
http://www.hobbyking.com/hobbyking/store/%5F%5F6317%5F%5FS0901%5FMicro%5FServo%5F12sec%5F1%5F8kg%5F10%5F5g%5F3v%5F.html
..i na kraju, HXT900 i HXT500 su isti kao i TowerPro servači 90 i 50, o tome sam se žalio ovdje:
http://www.flyfreak.net/nasforum/losi-trgovci-koj-je-kog-i-na-koji-nacin-zaj/msg35168/#msg35168
Slažem se s Diogenom, GWS servoi su solidni strojevi, pouzdani i cijenom prihvatljivi. Na svom hotlineru koristim Naro Max BB za flaperone i Pico BB za rep.
Nešto je u zraku...
Siniša
