Topic: Popis multija s flyfreak (Read 2617 times) previous topic - next topic
Primjer 1:
Tip letljelice:
FC: -kontroler
MTM: -razmak od motora do motora
Motori:
ESC:
PROP:
BAT:
AUW s BAT: (moze i prazan samo stavite oznaku)
Autonomija: -normalno letenje (ne hover, ne acro)
Komentar:
Model 1:
QUAD X
KKmulticopter
25cm
HK2205 1400KV
TURNIGY  PLUSH 18A
8X4
2200MAH 3S 25C
Model 2.
QUAD X
KKmulticopter
hk2212
hk12 A
2200
900 g
12 min
Model 3.
HEX FLAT +
MikroKopter
76 cm
MK3638
MKBlCtrl v2.0
13×4,5
6600mAh 4S 20C
4200g
7-11min
Model 4.
HEX FLAT +
KKmulticopter
Pulso 2814
Plush 40A
12×4,5
5000mAh 4S 20C
3800g
8-10min
Model 5.
QUAD X
DJI NAZA
45cm
2212 - 910kv
12A8×4,5
2200mAh 4S 40C
800g
12-14min
Model 6.
QUAD X
KKmulticopter
60cm
Rctimer 2830-14
Rctimer 30A
APC 10*4.5
3000mAh, 3S, 40C
1300g
10min
Model7.
TRICOPTER
AeroQuad
80
1220kv
25A
10x5
2200mah
Model 8.
QUAD X
KKmulticopter
45cm
910kv
30A
10x4.7
4000 4S
Model 9.
QUAD +
multiwii
45cm
RCT2830 750kv
HK blue 12A simonk
10x6
3S, 2200, 30C
850
8 min
Model 10
TRICOPTER
multiwiiitg
40cm
cf2822 1200kv
HK blue 12A simonk
 8X4
3S, 2200, 30C
900gr
7min
Hvala sudionicima ankete, dalje mozemo kako je stipe predlozio.
