Topic: gotove 360° Vektorske mlaznice (Read 5186 times) previous topic - next topic
Za one koji ne prate moj Grippen thread.
Na Infinitiju se pojavila gotova 2-osna vektorska mlaznica za 16$. Jedna je narucena pa bumo vidjeli jel cemu.
360 VECTOR THRUST NOZZLE SET
Two axis 360 thrust vector unit with a total range of motion of about 40  degrees. Unit is made of injection molded plastic and is a ball and socket  design with a molded foam exhaust nozzle trim ring. Inlet diameter is 62mm ID  and outlet diameter is 60mm ID. The unit's diameter at the largest point is 90mm  and the overall length is 94mm. Comes pre-assembled with a ball linkage in  place. Requires two micro servos to operate thrust vectoring (not included).  Total range of motion requires approximately 28mm of pushrod travel.
Specification:
  • 2 axis control
  • Weight: 42g
  • Inlet diameter: 62mm
  • Outlet diameter: 60mm
  • Overall length: 94mm
