Topic: X666 + KK2 moj prvi quad (Read 128718 times) previous topic - next topic
Odg: X666 + KK2 moj prvi quad
Reply #436
Ljudi bi rekli - Skuplja pita nego tepsija :)
Futaba 9C, Jr MC-20
Reply #438
Super :) dosta su jake ove ledice pojedinacne...
Reply #439
To su 5 mm, obicne su 3 mm, jako dobro se vide a moze se u njih gledati,
ovo gdje je zbunt ako svijetli ka tebi zasljepi te navecer pa sam morao okrenuti prema dolje.
Grozd ledice sam isprobao skoro sve boje, bijela, crvena, narandjasta,zuta, zelena.
Reply #440
Link na lampice ( ima i u video description)
Grozd
12 LED Cluster - RED
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=17192&aff=448825
Pojedinacne lidice
Multi Coloured Flashing 5mm LED with 1m Wire
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=23348&aff=448825
Produzni za servo, inace zgodan i za th range na KK2 postaviti, kada je vise motora znaju u razmaku paliti programing mod pa se desi da se ukljuci break i sl na nekim reglerima.
Servo Splitter Lead 1 Female to 5 male
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=29284&aff=448825
This handy little accessory will allow you to easily split a single receiver channel output into five. A handy accessory for those building multicopters as it gives you an easy way to program the throttle range into your ESC's all together prior to fitting them to your frame. It can also be used as a splitter in LED lighting systems.
Reply #441
Ja sam svoje sve stavio preko jednog relea koji je na posebnom kanalu tako da ih mogu palit/gasit preko stanice. Sviđa mi se jedna druga stvar koju sam vidio a to je da je čovjek spojio rasvjetu da mu počne treptat kada je baterija pri kraju - sad neznam kako je to napravio?
Futaba 9C, Jr MC-20
Reply #442
ne znam da li si mislio na ovo:
http://www.ebay.com/itm/1S-8S-Lipo-Battery-Tester-Low-Voltage-Checker-Indicator-LED-Buzzer-Alarm-RC-/251135759585?ssPageName=ADME:L:OC:US:3160
Stavi na konektor balansera.
Podesi na kojem naponu želiš da počne svirati ( ja stavljam 3,8V/ćeliji ) .
Prva ćelija u bateriji kojoj padne na taj napon on svira.
Meni služi i kod pražnjenja baterija ( ako nisam letio a napunio sam ih)  s žaruljom 12V/30W. Ne moram stalno paziti dokle je pao napon.
A sada i avione! :-(
Reply #443
Ne, već sada imam preko kk2 alarm ali ga ne čujem ako mi nije pred nosom. Mislio sam na ovako nešto: (premotati pred kraj)
HobbyKing Y-3 tri-copter flying indoors
...čovjek koristi MultiWii's koji već ima predviđen pin za LED. Možda bi se dalo nešto izmudrijati i sa buzzerom na kk2...
Futaba 9C, Jr MC-20
Reply #444
Tako ti lijepo leti tri da dobijem zelju i ja jednog da isprobam.
Bilo bi zgodno da ti se svjetla pale i gase raspareno da ne bude sve off on, recimo bocni pa srednji da uvijek imas neko svijetlo, za nocni let.
Reply #445
Danas sam upucavao za kolegu 1.5 fw na jednu KK2, OpenAero2 na drugu,
te 5 ESC flashao na SimonK, tako da sam do sada Simonizirao preko 30 komada.
Ujedno i mali video, kamerman je bila kcerka pa neka vas treskanje ne smeta.
http://www.youtube.com/watch?v=hKb5K2GwSkM
Reply #446
Koliko je tesko nastimati KK2 na dobro napravljenoj HEX-i!?
Nikakav, radi is prve kako treba s kopiranim parametrima!
Samo malo da nahvalim za uvod 4tm HEX, prepisali parametre s moje HEX SIX  i poletjeli na vjetru.
Gore je 1.5 fw i Simon ESC.
http://www.youtube.com/watch?v=TgQXWtSl9po
post ce ici i u hex thread ali ovdje je vise kao KK2 komentar.
Odg: Re: X666 + KK2 moj prvi quad
Reply #448
Jel ima toga kod nas za nabaviti?
Scorpion ne, ali sigurno ima ulja koja bi odgovarala za lezajeve,
treba vidjeti po auto dijelovi radnjama.
Ja sam prvo htjeo nabaviti ono u spreju za suho podmazivanje.
Mozda bi i legendarni WD40 odgovarao ali nisam strucnjak za ulja.
Reply #449
Ja uzeo. 31 kn. Nek se nađe. Ima motora. 26 motora imam na letilicama i refužo.  :'(
