Topic: X666 + KK2 moj prvi quad (Read 129521 times) previous topic - next topic
Odg: X666 + KK2 moj prvi quad
Reply #480
Kamera koju mislim staviti gore je 20g tako da to nije problem. To će biti za normalno letenje i povremeno snimanje jer sa avionom ne mogu stati u zraku i snimati. Ništa profesionalno...
Koliko treba biti razmak od propelera do propelera? Vidim da ljudi negdje imaju po 1,5-2 propelera razmak, a negdje jedva 2cm.
@srepfler
Oprostite na offtopic-u
Ostavi jedno 5cm razmak između propelera, ali može i više.
Reply #481
@srepfler
Barem 2-3 prsta razmaka, vise ne skodi.
Reply #483
Evo što je kolega rdamir napravio :)
Quad
Reply #484
Leti super stabilno,
cestitaj kolegi.
Reply #486
Quad
Dali su mu to možda ostale brake funkcije uključene na ESC-ima? Ako je tako neka ih isključi, trebalo bi biti još bolje.  :) Ali super je i sad.
Reply #487
Nisu uključene brake funkcije. To su Turnigy Plush 12A sa Silabovim kontrolerima, flashirani sa BLHeli firmwareom. Tamo nema brake opcija nego "Damping  Force", a to sam stavio na low.
Reply #488
Lijepo objasnjen Self Level setup
Video Preview Image
Reply #489
Izasao 1.6 fw za KK2
Kk2 v1.6 fw
Bug fixed #1:
3D vector correction feedback contaminated the gyro input signals.
Bug fixed #2:
Missing initialization of RX input signal variables. This could led to undefined RX signals if KK2 is powered up without RX connected, and then in turn cause the KK2 to arm. However no chance of motors starting because throttle is at idle as required for arming.
Changes of usage:
None.
Settings does not change when upgrading from V1.5.
Regarding bug#1:
The test quad did feel more precise after upgrade, but it was not a major change.
Regarding Self-level that looses its bearing after flying for a while:
This is a vibration problem. Get rid of the vibrations!
Also rapid flipping exceeding the rate of the gyros will cause this.
And I can confirm that the ESCs and servos, even those connected to M2-M8, must be removed when using a USB powered programmer! Else it is a chance of bricking the KK2 due to low voltage during flashing.
And finally, remember to remove the propeller, or otherwise disable the motors when working on your multicopter. During throttle calibration the propellers MUST BE REMOVED!
Also make a habit to disarm the KK2 before approaching and picking up the multicopter.
Reply #490
Uskoro i kuciste za KK2 u HK
Reply #491
ej jesi testirao ovaj 1.6
jel ima kakve razlike od predhodnika
malo sam lijen pa ako nije neka velika razlika d auopce ne updejtam  ;D
Reply #492
Vec sam pomislio da nema vise KK2 zainteresiranih,
prije se svaka verzija budno pratila i analizirala.
Ja sam testirao i meni je bolja nego 1.5,
10-15% bolje u mirnoci.
Testni let
Video Preview Image
test gopro gore u pripremi
Reply #493
ima im asmao su izgleda ljeni ko i ja p aim se neda tipkat  ;D
ako sam dobro skuzio postavke ostaju netreba se poslije opet namjestat gainovi
Reply #494
Nakon fleshanja s 1.5 sve ostaje nedirnuto,
ostale verzije ispocetka.
