pomoc oko dijelova August 19, 2012, 11:21:47 am pozz ekipa naime poceo sam raditi RC katamaran o 80cm duzin zanima me sto mi je sve potrbno da mi provukao osovinu od motora do propele koji dijelovi
Odg: pomoc oko dijelova Reply #1 – August 19, 2012, 12:38:56 pm imaš po 30usd kompletne armature pa prostudirajhttp://www.r2hobbies.com/rc-accessories/for-boats.htmlpozz i ugodna gradnja Karlo. 098-711-540, Sisak
Odg: pomoc oko dijelova Reply #2 – August 19, 2012, 02:29:42 pm HVALA hehe sada se bacam po ubrzanom postupku na plastificiranje mog brodica kad to zgotovin tk onda dolazi na red ovo
Odg: pomoc oko dijelova Reply #3 – September 05, 2012, 09:24:38 am dali je ovo kompaktibilno i dovoljno za katamaran duzine 80cm sirine 24cm i tezine cc 1,3kghttp://www.r2hobbies.com/25-5-rc-ep-deep-vee-arowana-mono-1-racing-boat-hardware-kit-rudder-shaft-propeller-wooden-mount.htmlhttp://www.r2hobbies.com/eurgle-rc-boat-2445-3500kv-370l-bl-brushless-inner-runner-motor-with-water-cooling-system.html
Odg: pomoc oko dijelova Reply #4 – September 05, 2012, 12:57:12 pm ova ti osovina bolje pašehttp://www.r2hobbies.com/32-3-rc-ep-epoxy-fiberglass-godspeed-u-catamaran-racing-boat-hardware-kit-rudder-shaft-propeller.htmlsa tim motorcicem si i nebus bas pomogao.
Odg: pomoc oko dijelova Reply #5 – September 05, 2012, 12:59:47 pm mi kazes onda koji motoric da bude zivahan i cc 40-50km/h ako to nije previs brzo po ovom sto si dao savijet meni bi trebao motor sa osovinom 5mm
Odg: pomoc oko dijelova Reply #6 – September 05, 2012, 01:04:29 pm http://www.ebay.com/itm/LEOPARD-Boat-3674-KV2200-4-Poles-Brushless-Motor-IM116-/300557027769?pt=Radio_Control_Parts_Accessories&hash=item45fa9849b9na 4s sa propelerom od 42mm...
Odg: pomoc oko dijelova Reply #7 – September 05, 2012, 01:14:48 pm a sto kazesna ovaj motor http://www.r2hobbies.com/eurgle-rc-boat-3660-1800kv-540l-bl-brushless-inner-runner-motor-with-water-cooling-system.htmlova osovina http://www.r2hobbies.com/25-5-rc-ep-deep-vee-ocean-force-mono-racing-boat-hardware-kit-rudder-shaft-propeller-wooden-mount.htmli ovo mislim da bi mi trebalohttp://www.ebay.com/itm/RC-Model-Boat-Submarine-Universal-joints-ID-4mm-X-5mm-Coupling-4mm-To-5mm-/280938171651?pt=Radio_Control_Vehicles&hash=item4169384d03#ht_1620wt_952molio bi komentar
Re: pomoc oko dijelova Reply #8 – September 05, 2012, 04:56:00 pm Za motor neznam...nisi reko na koji napon ces ga spojit.Sent from my HTC Wildfire S A510e using Tapatalk 2
Odg: pomoc oko dijelova Reply #9 – September 06, 2012, 10:38:42 am novi sam u ovom tako da se ne putim toliko u to nesto bi ugradio da nebude sad profi ali ni smeceevo par slika od moga uradka: dali bi ovaj prop bio dobar http://www.r2hobbies.com/4-43-26-09mm-rc-ep-boat-plastic-propeller.htmlna motorhttp://www.hobbyking.com/hobbyking/store/__25091__3660SL_3180kv_Brushless_Inrunner_WaterCooled_.html
Odg: pomoc oko dijelova Reply #10 – September 06, 2012, 08:11:57 pm bravo bravo... jako dobro odrađeno.... daj stavi i sliku odispod..... vlakna??
Odg: pomoc oko dijelova Reply #11 – September 06, 2012, 08:36:06 pm Quote from: dankopermozer on September 06, 2012, 08:11:57 pmbravo bravo... jako dobro odrađeno.... daj stavi i sliku odispod..... vlakna??konstrukcija broda je napravljena d šperploće 5mm i presvuceno balzom od 2mm nakon cega je cili brod namazan jednim slojem staklene vune u kombinaciji sa smolom a drugi sloj je isao samo smola kad malo uvatim vrimena otvorit cu novu temu i opisati sve sa slikama kako je brodic nastao jedno znam je tezi od tvornickih ali bocu od 1.5L drzi ka bebu doslovno mozes bubnut jos...
Odg: pomoc oko dijelova Reply #12 – September 07, 2012, 06:07:18 pm može komentar na ovo sve i na to bi isa baterija 4s od 5000mAhhttp://www.r2hobbies.com/eurgle-rc-boat-3660-1800kv-540l-bl-brushless-inner-runner-motor-with-water-cooling-system.htmlhttp://www.r2hobbies.com/rc-boat-fiberglass-25mm-52mm-540-motor-mount-with-water-cooling-system.htmlhttp://www.r2hobbies.com/4-43-26-09mm-rc-ep-boat-plastic-propeller.htmlhttp://www.ebay.com/itm/universal-joint-coupling-5mm-to-4mm-rc-model-boat-scale-/160796573408?pt=UK_ToysGames_RadioControlled_JN&hash=item257038fee0http://www.r2hobbies.com/25-5-rc-ep-deep-vee-ocean-force-mono-racing-boat-hardware-kit-rudder-shaft-propeller-wooden-mount.htmlhttp://www.r2hobbies.com/turborix-cnc-aluminum-sailing-boat-servo-wheel-for-futaba-servo-25t-1pc.htmlsad dali je potrebno uzivati onaj set za montazu motora ili je dovoljno sam napraviti???bili ovaj motor izdrza na bateriji od 5000mAh voziti 20min cc da nije kontsntno ful gas trazim neko okvirno negledamo u minutu hehehehttp://www.hobbyking.com/hobbyking/store/__25091__3660SL_3180kv_Brushless_Inrunner_WaterCooled_.html
Odg: pomoc oko dijelova Reply #13 – September 25, 2012, 12:16:08 pm stigli dijelovi i sada krece montaza bude i slika prvi katamaran na krutu osovinu pa nek mu bog pomogne )
Odg: pomoc oko dijelova Reply #14 – September 25, 2012, 01:13:08 pm samo jako pazi sa podmazivanjem.... : "OD VIŠKA GLAVA NE BOLI!"
