Topic: RMilec JR Module i Futaba u HK (Read 2049 times) previous topic - next topic
Odg: RMilec JR Module u HK
170$ sve
The RMILEC TS4047 10CH 2.5W UHF Module System offers the ultimate in range for your FPV model. It can be used with any JR style module transmitter. This package includes the TS4047 UHF transmitting module, RD4047P UHF 10CH receiver and all necessary hardware.
Included in box:
TS4047 transmitter module (JR style)
RD4047P 10CH receiver
Transmitter module antenna
Antenna rack
All necessary hardware/wire leads
TS4047 Module Specifications:
Hardware frequency Range: 400MHz to 470MHz
Frequency stability: 2.5ppm
Output low-pass Filter: NONE
- Band 1
Frequency Range: 415Mhz-445Mhz
Step frequency: 480Khz
Channel : 70
- Band 2
Frequency Range: 433.05MHz -434.79MHz
Step frequency: 30Khz
Channel: 70
Low Output Power: 30DB -31DB Peak  (0.9W-1.2W)
High Output Power: 33DB -34DB Peak (1.9W-2.5W)
Low rate: 40Hz @10Kbps
High rate: 66Hz @15Kbps
RF interface impedance: 50 Ohm
Supply Voltage: 8.4V to 16V
Reverse battery protection: NONE
Logic Voltage: 3-12V
Current:
330mA/520mA (@50 Ohm load,12V Supply Voltage)
250mA/440mA (@No-load,12V Supply Voltage)
950mA/1.6A (@RF Short circuit,12V Supply Voltage)
Temperature: 50 to 70 Degrees Celsius
RD4047P Receiver Specifications:
Frequency Range: 400MHz to 470MHz
Sensitivity :
-112 DBM @0.1EBR(40Hz Refresh rate)(10Kbps low rate )
-111 DBM @0.1EBR(50Hz Refresh rate)
-110 DBM @0.1EBR(66Hz Refresh rate) (15Kbps high rate)
-108 DBM @0.1EBR(90Hz Refresh rate)
-104 DBM @0.1EBR(125Hz Refresh rate)
-104 DBM @0.1EBR(166Hz Refresh rate)
-101 DBM @0.1EBR(250Hz Refresh rate)
F/S turn on condition: >0.99EBR
Antenna gain: 2.15DBM
- Low rate mode
Refresh rate: 40Hz
Hopping rate: 40Hz
Hopping cycle: 13Hz
Recover time: 77mS
- High rate mode
Refresh rate: 66Hz
Hopping rate: 66Hz
Hopping cycle: 22Hz
Recover time: 45mS
Response Time: 4mS to 25mS
PWM Output accuracy: 0.5uS step ERROR<20PPM
PWM Output range: 0.5mS-2.5mS
PWM output cycle: 55Hz  @Normal mode / 192Hz @Fast mode
PPM Output accuracy: 0.5uS step ERROR<20PPM
PPM Output range: 0.5mS-2.5mS Each channel
PPM output cycle:
50Hz@Normal mode & 1mS to 2mS Output
42Hz to 50Hz  @Normal mode & 0.5mS to 2.5mS Output
50Hz to 83Hz  @Fast mode   & 1mS to 2mS Output
42Hz to 125Hz @Fast mode   & 0.5mS to 2.5mS
PPM sync pulse width:
4mS to 16mS  Automatic adjust @Normal mode / 4mS unchanging @Fast mode
RSSI output range: 0-3.3V (RF signal weak <0.8V)
Recommend Supply Voltage: 3.5V to 8.4V
Shutdown voltage: 3 V
Damage voltage: >15V
Reverse breakdown voltage: >-15V
Output ports withstand voltage: >12V
Normal Current: <60mA
Operating Temperature: –40 to +80 °C
Low frequency Power supply noise filter: Include
High frequency noise filter: Include
