Topic: Mini Rechargeable 2.4GHz 4-CH Quad-Rotor (Read 6527 times) previous topic - next topic
Odg: Mini Rechargeable 2.4GHz 4-CH Quad-Rotor
imam ja dva komada ali boljeg modela  i jedan ide na prodaju idući tjedan .
moj je orginal Walkera ladybird cjena kompleta sa 4 kanalnom stanicom bude cca 500 kn
walkera za razliku od ovoga ima 6 osni žiroskop .ovo je jeftinija kopija sa 3 osnim žircem
šta da ti kažem svaki dan skurim barem 8 baterija cca 1 sat leta. zarazno do bola pogotovo za kišnih i vjetrovitih dana kada nemožeš letjeti vani sa velikim .
evo orginala:
Walkera QR Ladybird Quadcopter Review
Evo ja si kupio 232.92 HRK pa čekam da vidim  ;D
Kakvih 6 osi? Ne kužim
WALKERA QR Lady Bird V2 6 Axis Gyro 4CH UFO with DEVO 4 Transmitter RTF (Green) - 2.4GHz
Features:
In-built telemetry function also enables and simplifies flight battery voltage monitoring
The latest 6-axis flight control system, with adjustable gyro sensitivity, permits super stable flight
The attractive, durable and lifelike simulation-design canopy delights with its bright colors and state-of-the-art workmanship
8.5x8.5mm micro mutli-rotor uses a super lightweight airframe with excellent durability
7mm coreless motors offer immediate response and superb efficiency
Stability and agility in flight simplify professional 3D maneuvers like pirouettes, 3D fun flips, rolls and more
Compatible with the DEVO series radios (S type required for telemetry information)
Specification:
Motors (x4): 0720RN57A-9M-130NL52
Receiver: RX2643H-D
Battery: 3.7V 240mAh
Height: 3cm
Radio range: ≤30m
Flight time: 6-8min
Dimension: 100*100*34mm
Ja narucio jos malo jace baterije, 350mAh 1S, ove turnigy nanoshit se napirile od koristenja, svih 5 komada, sada s njima nakon par min letenja nakon sto ih napunim samo dodje do poda i onda se pri podu lebdeci moze voziti kao autic jos par minuta, a macak vreba iz kuta ali se ne usudi napast, hehe.
Uglavnom prefora quad i za u kuci i vani. Jako je brz i upravljiv, volim se punim gasom zapicit u zavjesu i onda kocit tako da bude u zadnji cas, to jako smjesno izgleda, ali sto cemo kad si pomoc nemozemo, lijecenje mozemo naci jedino u Paucju.
Hjooj:D
Jedva cekam rodendan da dobim pare i ocuuuu toooo narucitiiii:D
Postoji kakva mogucnost to bindati na 9X stanicu?
pozz
MiniPet 4 channel quad :: Hype WoW! :D
Ne, moguce je jedino bindati na Walkera/Devo.
aha, ok:D ja si bum narucil jednoga pa sta bude, bude:D
Obavezno provjeri polaritet zica u konektoru baterije prije nego je spojis   :)
Samo jos jedno pitanje: Ne placa se na to carina?   ;)
