Topic: GAUI Hurricane 255 (Read 2379 times) previous topic - next topic
GAUI Hurricane 255
Evo neceg mrvicu veceg od Trexa 250, novi Hurricane.
http://www.gaui.com.tw/html-en/products/ep255/ep255kit.html
Lepo zgleda.
Evo sto kaze GAUI
  • The best 3D capable micro helicopter which use 11.1V/3S1P/LiPo battery in this class.
  • Partial assembled modulate parts which is easy for completion.
  • Partial assembled kit comes with BL motor and 18A ESC.
  • Newtail unit come with Integrated CNC Tail Gear Case/ Arc Tail Pitch Leverwith double bearings/ Frictionless Tail Pitch Slider/ New Tail OutputShaft with CNC Pulley/ New Tail Rotor Yoke/ New Tail Grips whichproduce precision and the best tail control.
  • 9mm CNC Black anodized Tail Boom and New CNC Motor Mount provides the high strength and rigidity to Tail.
  • New CNC Main Rotor Yoke and Spindle.
  • New CNC Main Grips.
  • New layout for CCPM servos which results in a precisely control to swashplate.
                  CNC Motor Mount comes with 2 motor mounts (Front or Rear).
  • Kit comes with KV3400 BL Motor and 15T pinion which produces quick power response and the best power efficiency to 3D maneuver.
  • High Performance New Stabilizer Blades and Tail Rotor Blades.
  • New light-weight streamlined FRP canopy.
  • New CF Fin and Tail.
  • Equipped with CNC Universal Battery Plate provides more options to the C.G. adjustment and the installing of electronic gears.
  • All mechanism equipped with Precision CNC Parts.
  • Fully equipped ball bearings.(35 pieces of micro bearings)
          Specification:
  • Overall length: 488mm (including cabin & canopy)
  • Main rotor diameter: 550mm
  • Tail rotor diameter: 110mm
  • Motor: KV3400 brushless motor (included)
  • ESC : 18A ESC (included)
  • Flying weight: 360g ~ 380g (It may vary according to size of a battery pack and R/C gears.)
  • Main rotor blades: 250mm CF Blades(included)
  • Flying duration: 5~6 minutes with 11.1v/900mah Li-Po battery
Usporedba sa Hurricane 200
http://www.gaui.com.tw/255vs200/index01.html
Odg: GAUI Hurricane 255
Sviđa mi se kutija.
Outrage Fusion 50
