Topic: HITEC receiver klonovi u HK (Read 3900 times) previous topic - next topic
Cijena ok,
da li pase i za A9?
http://www.hobbyking.com/hobbyking/store/__27175__FrSky_2_4Ghz_A_FHSS_Compatible_8CH_Receiver_Hitec_Minima_compatible_.html
http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=701
The FrSky Minima series receivers are a great option for users of Hitec A-FHSS radio systems. They offer excellent performance and additional features. This receiver is also HV (high voltage) capable featuring an input voltage range of 3.5~16V.
Compatibility:
Compatible with Hitec Minima series 2.4Ghz A-FHSS transmitters
Features:
• Hitec Minima 2.4Ghz A-FHSS Compatible
• Supports PPM and RSSI Output
• Long Range >1.5km
Specs:
Number of Channels: 8
Operating Voltage Range: 3.5V~16V
Operating Current: 30mA
Operating Range: Full Range (>1.5km)
Dimension: 44x24x14mm
Weight: 9.3g
*Note: This unit is not designed, manufactured or supported by Hitec, nor is it a copy of a Hitec receiver.
Odg: HITEC receiver klonovi u HK
strašno dobra vijest . i mene zanima dali radi na aurori 9 ali ne vidim razloga zašto ne . čim budem siguran da radi naručujem 2 komada .
Ja naručio pa da vidim jel radi a koja je razlika u dometu u odnosu na orginal jer ću ih .
Ali za zagija i ove varijante šta letim ispred nosam je sigurno dobro :)
istestiraj pa javi , nebi se čudio da nema razlike .
Upitao na HK, kazu da bi trebalo da radi, jedino nema telemetriju kao ni orginal Minima.
Ali ako je signal 1.5 km, ima RSSI cini mi se odlicno, pogotovo sto ne treba kemijati s modulom.
šteta za telemetriju , jako mi je korisna ali ako domet radi za 21$ nebudem gledao u zube .
evo što piše lik o kompatibilnosti sa aurorom 9 .
citat:
Yes its compatible with the Aurora 9. The only thing you need to check is that your Spectra transmitter module is up to date - on Version 3.01.
You can check if its at the latest version by putting the module into bind mode (pressing the button when powering on) and then pressing the button again. If it changes between a flashing Red and a flashing Blue (and vice-versa) then its compatible. Flashing Red LED = Optima bind mode, Flashing Blue LED = Minima bind mode. If its out of date, either buy and use a Hitec HPP-22 to update it, or send it off to your nearest Hitec service centre.
probao na svojoj i svijetli i crveno i plavo .
pa bilo je i vrijeme da netko napravi zamjenske, ovi cak imaju PPM out i RSSI out sta ni orginal Hitec nema nijedan
e da, da je barem status baterije prikazan
LOL, išao malo bezveze lurkat po HobbyKingu i naletim na ovo:
http://www.hobbyking.com/hobbyking/store/__24785__FrSky_TFR8_SB_8ch_2_4Ghz_S_BUS_Receiver_FASST_Compatible.html
Znači S-Bus divljak za Futabu - ZAKON!  :)
A sjećam se da je bila priča tu na forumu da nema teorije da će izbaciti nekakve S-Bus Rx-e za male novce jer je kao neki chip skup il kaj već?! Uglavnom, tu je :)
http://www.youtube.com/watch?v=I30I1URRIxs
Sve prodali. (8CH)
Imas i varijantu od Corone
http://www.hobbyking.com/hobbyking/store/__24226__Corona_R6FA_SB_2_4Ghz_FASST_Compatible_S_BUS_Receiver.html
The CORONA 2.4GHz R6FA-SB Spread Spectrum FASST Compatible Receiver is designed for use with FUTABA’s FASST 2.4GHz transmitters; including the 3PM, 3PKS, 3VCS, 3GR, 4PK(S), TM7, TM8, TM10, TM14 and the T6EX-2.4G, 7C-2.4G, 8FG, 10CG, 12FG. The R6FA-SB receiver supplies a more useful mode for users. The R6FA-SB supports not only FUTABA’s FASST air system, but FASST surface systems as well. This receiver supports up to 7-channels with continuous PPM (positive and negative) output, RSSI output and S.BUS output. It also
supports 6 channel high speed PPM(HS) mode to optimize helicopter response control and S.BUS output.
Under S.BUS output mode, R6FA-SB supplies 12 proportional channels and 2 DG channels. Therefore, the R6FA-SB becomes a 14-channel receiver when using S.BUS output.
Specs:
Operating Current: 50mA max
Operating Voltage:  3.6 ~10V
Latency:
 7mS for independent 6 channel (HS) output@ FASST multi-channel mode
 14mS for independent 7 channel (LS) output and S.BUS output @ FASST multi-channel mode
 8ms for independent 6 channel (HS) output@ FASST 7ch mode
 16mS for independent 7 channel (LS) output and S.BUS output @ FASST 7ch mode
 14ms for independent 3 channel output@ FASST surface system C1 CODE mode
Sensitivity: about -100dBm
Operation temperature: -10~80 deg C
Dimensions: 48x27x12mm
Weight: 11g
